hot z
Old Sep 30, 2011 | 01:04 AM
gunsavy's Avatar
hot z
i have 1995 z28 that has started overheating so far i have had the system flushed changed the t stat and replaced the water pump i tried bleeding the system but after reading many of the threads i moght not have done it right but what im confused about is why when it overheats is the radiator is not hot i have checked the oil and there is no mix so my guess is the heads are ok i would appreciate any help (the temp has gone up but i shut it off before it got to the red). thanks
Old Sep 30, 2011 | 01:37 AM
Seahawksax's Avatar
I had the same problem.. i ended up doin a head job anyways.. it was super warpped on the driver side...i had no smoke and no mix when i took them off
1993 supercharged camaro z28
Old Sep 30, 2011 | 05:03 PM
Re: hot z
Did you buy a thermostat specifically designed for the LT1's reverse flow cooling system?
Did you read Shoebox's guide to cooling system problems?
http://shbox.com/1/4th_gen_tech2.html#cooling
Do the fans come on when the temperature reaches 226*F?
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
