Hot car....
Old Jun 24, 2004 | 09:05 PM
a mean 94z's Avatar
Hot car....
Posted this on LS1tech, but I"ll probably get better feedback on here....
Got the header install done....and this car moves! Sounds extremely bad *** too. But the question is, now I'm driving the car around and the water temp. gauge is going outta control, it's at like 215-220.....the engine temp. is now a little above the half way mark.
Does anyone have any ideas??
Old Jun 24, 2004 | 09:07 PM
simple's Avatar
dont you work at a performance shop??
neway there is prolly air in the system or you are low on coolant
med_reject's Avatar
dumb question... did u bleed the coolant lines properly?
Old Jun 24, 2004 | 09:11 PM
a mean 94z's Avatar
I never drained the coolant while doing the header install.....should I bleed it anyway?
Old Jun 24, 2004 | 09:32 PM
I would not call your temps out of control unless they are way different than they were before, in the same circumstances. Since the temp gauge sensor is in the head, it might be a good thing to check on the welfare of the lead going to it (often a casualty of new headers).
Old Jun 24, 2004 | 10:29 PM
Spinner's Avatar
I damaged my lead months and months back, is the solution just soldering on a new pigtail and connector to the wire?
Old Jun 24, 2004 | 10:42 PM
wdz_lt1's Avatar
exact same thing happened to my friend...and he forgot to bleed the lines
Old Jun 24, 2004 | 10:52 PM
That will certainly work, though if you just have a damaged piece of wire, just splice out the damage. The pig tails are not real cheap. The pig tail is listed in a small database in the wiring section on my page.
Old Jun 24, 2004 | 11:33 PM
a mean 94z's Avatar
But what about my AutoMeter Water temp. gauge, it reads like 240 and used to read like 180?
Old Jun 24, 2004 | 11:37 PM
Well, that would have been good info to post from the beginning. Did you happen to leave your air dam off? What are the precise driving conditions that it gets this high?
Old Jun 25, 2004 | 12:03 AM
a mean 94z's Avatar
I did leave the front air dam off....
And just normal driving, maybe after a blast from 1 to 2nd gear at around 5500rpms
Old Jun 25, 2004 | 12:17 AM
Gotta have the air dam on. It will run hot without it.
Old Jun 25, 2004 | 12:19 AM
a mean 94z's Avatar
Thanks, I will put in on tomorrow and take the car out.
Why does that happen?
Old Jun 25, 2004 | 12:42 AM
ss#1230's Avatar
the air dam routes air up through the radiator. without it, most of your air will pass right by and go under the car. so your radiator is sitting in a hot void, the only airflow your gonna have is from you fans....
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
