Hot cam with a knock problem...
Old Oct 12, 2004 | 10:18 PM
TransAm-Z's Avatar
I just got my motor running again and I am having a problem with knock. I can hear the car knocking under a load, and in the 10 mins I had the car out the knock sensor picked up over 10,000 knocks and was pulling timming every now and then.
I am running a 355 with KB Hyper. pistons. (cr ~10.8)
Hot cam with 1.6 RR's & guideplates
Advanced Induction Econo ported Heads with larger valves
32# Delphi injectors
New Opti
LT4 knock module
PCMforless tune with timing pulled back (timing hits about 30 deg at 4000 RPM)
160 deg thermostat (car running around 180 deg)
93 Octane pump gas
Also running stock exhuast manifolds/TB
Anyone have any ideas on what I should do? Should I keep pulling timing back until I have no power? Or would a colder spark-plug be benificial?
Old Oct 13, 2004 | 06:40 AM
TransAm-Z's Avatar
Re: Hot cam with a knock problem...
Has anyone else had a similar problem?
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
