Hot Cam in the 94....
Old Sep 10, 2007 | 10:04 PM
red_94z's Avatar
Well, pretty soon ill be gettin the 200+k motor in my 94 LT1 rebuilt. So I was thinkin since I got a Hot Cam Kit layin around Id trow it in there while the motor was out and maybe do some head work(P&P,mill....) the car has some kinda aftermaret cat back,52mm tb,stock manifolds, all the other bolt ons free mods etc.....
So, what else would you guys add if it was your motor? and what kinda power would you expect from it?
Old Sep 10, 2007 | 10:19 PM
chevelles101's Avatar
If you're going to do the hotcam or any sort of aftermarket cam you're going to want some long tube headers to get the most out your car.
Old Sep 10, 2007 | 10:20 PM
rasputin's Avatar
Dont call me an expert, or take what I say with 100% accuracy, but I think you should get some long tubes before you do anything to the heads. A bunch of people will say you need to go larger with the cam, but if you cant afford it, and its laying around, I say why not use it. I would recommend a pocket port and a valve job while the heads are off, stay away from full porting as you should probably change the cam if you do a full port job.
That should be pretty affordable if you have money after the long tubes and a nice x pipe. But really focus on the exhaust before doing anything else, and you should have a 12 second car with at least 330rwhp.
Old Sep 10, 2007 | 10:29 PM
red_94z's Avatar
LOL....Yea, I prob will get some long tubes, and the hot cam kit is literally just layin around. This was my first car soooo i just figured after all these years she deserved a lil treat You think borin er out a lil may be worth while? Id also like to get the compresion up some.
p.s. i forgot to mention the 3500 stall, and 4.10s....
Old Sep 10, 2007 | 11:53 PM
rasputin's Avatar
4.10's, that high of stall, hot cam, and some long tubes: should be a beast! a stroker motor wont be worth your money with that cam. often times when people get strokers and ask what cam, many will say gm 847 which is the biggest. i dont know enough to tell you, but what I do know tells me keep it simple stupid
Old Sep 11, 2007 | 12:04 AM
red_94z's Avatar
Thank ya mad monk I really wasnt expectin too much out of the Hot cam.....Itll be nice to have another "beast"
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
