Hot cam with 396; to small or what
Subscribe
Mar 30, 2005 | 08:07 PM
Currently running a hot cam with a 396 thinking about going to the CC305 trying to find pros and cons on both cams with stroker. Anybody else running this combo
Reply
Mar 30, 2005 | 08:18 PM
Re: Hot cam with 396; to small or what
Yes, that cam is waaaaay too small IMO for a good 396 build up. Are your heads still stock too?
Depending upon what your goals are (street, strip, both), I'd look more into a CC306, GM847, or especially a custom grind cam for your motor. Don't forget you're going to need a good set of heads to match that cam in order to take advantage of all those extra cubes if you really want to make good power...
Good luck,
Mike
Reply
Mar 30, 2005 | 08:47 PM
cc305 is pretty much the same as a hot cam. I would go with a custom grind.
Reply
Mar 30, 2005 | 08:48 PM
It has an complete LT4 top end. Just looking for a little street/strip fun
Reply
Mar 30, 2005 | 08:55 PM
most people dont even want to run a hotcam in their stock 350's unless emissions is an issue
i think i went pretty mild with my 230/236 544/554 in my 383. im sure i will go bigger down the road
Reply
Mar 30, 2005 | 08:58 PM
Quote: i think i went pretty mild with my 330/336 544/554 in my 383. im sure i will go bigger down the road
How much bigger can you go, 360/360?
Reply
Mar 30, 2005 | 09:04 PM
Quote: How much bigger can you go, 360/360?
sorry it was a typo should have been 230/236
Reply
Mar 30, 2005 | 09:55 PM
Quote: sorry it was a typo should have been 230/236
how about 254/262 650/658 with a 109 lsa
Reply
Mar 30, 2005 | 10:05 PM
Quote: how about 254/262 650/658 with a 109 lsa
that's some huge lift there, with serious lope. better have some beefy springs for it.
Reply
Mar 31, 2005 | 02:55 PM
You can go with a bigger cam in a 396. It will be more streetable and actually better for emmissions. I have heard of guys with the CC306 and a 383 or 396 passing emmissions. The extra cubes seem to help ensure everything burns fully.
Reply
Mar 31, 2005 | 07:01 PM
Thanks; A king is Born
Reply
Subscribe
