Hose on TB...what is it?
Old Feb 20, 2004 | 01:31 PM
Raped Ape's Avatar
I started pulling my TB off to replace my IAC and do the tb bypass. There is a hose on the passanger side of the tb. It's not the one that goes to the valve cover, but the little one under that one.
The 90 degree rubber elbow on it is cracked pretty bad. What do I need to get at AutoZone to replace the elbow? Thanks.
Old Feb 20, 2004 | 01:39 PM
It is the vacuum feed to the EVAP solenoid. GM p/n 10105324.
Old Feb 20, 2004 | 01:44 PM
Raped Ape's Avatar
Thank you Rob. You're the man.
Old Mar 31, 2004 | 01:57 AM
CMYZ28's Avatar
would this make the car idle bad??
Old Mar 31, 2004 | 02:45 AM
1982z28with18s's Avatar
When the car was running I removed it/put it back on and the idle changed. Some good ole duct tape seemed to fix the problem for now until a new one comes in.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
