too much spark advance???
Old Mar 31, 2004 | 12:12 AM
TUFF LT1's Avatar
Just installed a cam and I'm having trouble with the car running bad. The car runs fine (for a couple of minutes) if you start it after it has been sitting all night. But then it starts to have a slight miss and a poping sound, not a back fire out of the exhaust?? Now it is really obvious when you try taking off in first gear. I ran a scan on it and the only thing that I can see that dosn't look right is that at idle my spark advance is 24 and once I start to push on the gas to go it jumps to 45 and is maxed out it looks like. Could this be causing this problem? Can or should I bump up the max timing with tunercat? I've already done all of the basic things such as plugs and wires. The wires are all in the right position. The timing chain is lined up dot to dot. I'm about fed up. Will the dealership be able to see more on their computer than what I'm seeing with freescan and datamaster??? Thanks
Old Mar 31, 2004 | 12:16 AM
TUFF LT1's Avatar
Oh yea, and the valves have been adjusted and re-adjusted so I don't think that that is the problem.
Old Mar 31, 2004 | 02:51 AM
jtk's Avatar
jtk
the timing sounds like it could be correct. 20 somthing at idle and 45 light load right? it than should drop down to if you gas it.
from what you describe it realy dose sound like a leaky or stuck valve to me
jwade88
Jun 14, 2015 09:38 PM
zxtce
May 7, 2015 08:53 PM
blkWidow
May 3, 2015 08:42 AM
charchri4
Apr 14, 2015 06:40 PM
