hose replacements
Old Mar 28, 2004 | 12:20 AM
NewbieWar's Avatar
hose replacements
ok i ordered all my radiator hoses from gmpartsdirect, and it says i will receive them on monday, i get back from work about 6:00 P.M. how long would you think it would take you?
or how long does the dealers charge? (job hours?)
cause i wanna get it finnished asap...
ohh another thing... what happens if u fill the overflow w/ water but the car leaks... my car leaks a lot and i wanna put as much water in the system as possible, so ive been filling my overflow w/ water and topping off the radator (probably after 100 miles ive lost a gallon of water ) so im keeping it full..
Old Mar 28, 2004 | 12:42 AM
97WS6SCharged's Avatar
Hmm... drain the radiator and remove all the hoses? Probably about an hour give or take how skillful you are at getting those goofy factory hose clamps off. The hardest ones, IMO, are the ones at the sides of the radiator, the water pump sides are pretty straight forward.
Old Mar 28, 2004 | 01:23 AM
Zack's Avatar
i would figure out that leak ASAP and fix it, not put it off
Old Mar 28, 2004 | 10:01 AM
NewbieWar's Avatar
i know where its coming from its from one of the hoses coming out of the water pump... and its spraying up and hitting my insulation on my hood...
i can see it its like the size and shape of this letter ---> u
trust me i keep good tabs on it
Old Mar 28, 2004 | 10:43 AM
CamaroBoy96Z28's Avatar
I had that same issue 2 years ago but didnt fix it myself. I just took out my radiator and drained the block though. That whole process probably took about an hour or so. The hardest part is getting the drain plugs off. The only accessible one was the knock sensor because I couldnt get a wrench on the other side due to the Longtubes in the way.
Old Mar 28, 2004 | 05:14 PM
NewbieWar's Avatar
i wont be drainning it i just assumed that the hoses being off would allow it to drain out... but maybe not
i flushed it not to long after i purchased it
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
stopthatman
Feb 9, 2015 09:00 PM
pologreen97z
Dec 2, 2014 10:42 AM
ro2207
Dec 1, 2014 01:02 AM
