I need wiring a replacement sealed beam harness
Old Mar 26, 2004 | 07:55 PM
lbrowne's Avatar
Exclamation I need wiring a replacement sealed beam harness
I'm not sure how to wire it or if it doesn't matter.
The replacement harness I have from NAPA has 3 black wires. I think the wires that are left on the car are coloured...
Help
Old Mar 26, 2004 | 09:30 PM
Most replacement pigtails have no color code because they can be used on many different cars. Look at the one on the other side for guidance.
Old Mar 26, 2004 | 10:14 PM
lbrowne's Avatar
I would if it had the harness on it......
Both had been cut out.
Old Mar 27, 2004 | 11:52 PM
lbrowne's Avatar
so....any help?
Old Mar 28, 2004 | 03:35 PM
If you can find the cavity designations on the connector,
A=tan
B=lt green
C=black
Old Mar 28, 2004 | 04:44 PM
lbrowne's Avatar
On my connector there are now markings.
If it is wired wrong what happens?
Is it safe to assume the bottom prong hole is the ground? meaning its the black wire?
thanks...
lbrowne
Old Mar 28, 2004 | 05:14 PM
thanks...
lbrowne
I would guess that, but don't know for sure. There is not a diagram of that connector in the manual and I don't have a Firebird that I could go look at.
Iamherefornow
Jan 26, 2015 04:57 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Jazsun
Dec 29, 2014 12:14 PM
CobraEatr
Jul 29, 2002 11:46 AM
