Horrible Oil Leak.
Old 10-06-2004, 09:40 PM
Loading's Avatar
Horrible Oil Leak.
Hello all, I've got a horrible horrible oil leak in my 1994 Trans Am. It only leaks when cold, and it's really quite bad. 2 steady streams from when I back out of the driveway, to the road, then up the road till the stop sign about 10 feet up. It seems to stop around there. (If I pull over up the road and sit for a couple minutes, just a couple drops, I think it's just residue.)
It seems to be leaking from the rear left side of the engine. (It comes off the oil filter, the oil filter is *not* leaking.)
I took the car up to a friends house, and tonight we removed the intake manifold. I was hoping it was the intake manifold gasket, but that seemed absolutly fine. Feeling around the back of the block just below where the intake manifold would have been just got our fingers dirty with dirt. Didn't seem to be a lot of oil back there, and the seal looked fine. On friday or saturday we'll reinstall the intake manifold, but in the meantime, I'm wondering if I should keep it off, incase there's anything else to check?
Thanks.
PS. Anyone ever take their car into a mechanic to get an oil leak fixed? How expensive were the repairs?
Loading is offline
Old 10-07-2004, 01:35 AM
97WS6SCharged's Avatar
Re: Horrible Oil Leak.
If your car has an oil cooler, you may want to check the adapter and the lines for leaks. Also, try changing the oil filter, sometimes some of the gasket from the previous filter will get caught and cause a leak like that. After that, I'd say invest in some of that dye that glows under a black light and see if you can track down the source.
97WS6SCharged is offline
Old 10-07-2004, 01:48 AM
944v8inDFW's Avatar
Oil leakage in that area may be the sending unit as well
944v8inDFW is offline
Old 10-07-2004, 06:52 AM
jeremyferguson's Avatar
I was thinking the sending unit as well, but I think it was above the filter only on the '93s. I think in '94 it moved to below the egr valve......not sure, but definitely something to check in to......
jeremyferguson is offline
Old 10-07-2004, 01:19 PM
Loading's Avatar
I took the sending unit out as well, and put some thread sealer stuff around the bolt. Didn't notice tooo much oil from it. I think it was mostly dirt/water. (Rear of my block is dirty and wet)
It's a manual car, so no oil cooler.
Could it possibly be the oil pan?
Loading is offline
Old 10-07-2004, 03:30 PM
gb95zconv's Avatar
Manual cars can have coolers too.
gb95zconv is offline
Old 10-07-2004, 04:43 PM
97s10ondubs's Avatar
^wheres it at? I have a fluid leak somewhere and cant tell what it is
97s10ondubs is offline
Old 10-07-2004, 05:08 PM
944v8inDFW's Avatar
You may want to do yourself a favor and buy one of the UV die kits to track down leaks. Best $20 i have ever spent on tools except a bigger hammer!
Old 10-07-2004, 05:32 PM
^funny you should say that i did it and cannot find the leak, only pin sized neon spots like 4 or 5 of them, around the oil pan and block, something is leaking when i punch it, i cant tell if its white smoke or blue, but i thought it was coming off of the y-pipe because thats what it looks like.
Old 11-27-2004, 02:28 PM
93ZM6Tally's Avatar
You ever figure this out. I'm apparently having a leak that fits your description perfectly. I'm about to try the UV dye. I've changed and checked everything, Intake, Oil Sending Unit, (93 Car), Oil filter, Oil filter adapter. I can't figure it out and it's driving me crazy.
93ZM6Tally is offline
Old 11-27-2004, 03:33 PM
lol, no, did the dye and as you can see i couldnt find it, i just live with it
RX Speed Works
07-24-2015 02:25 PM
big_mac421
07-13-2015 03:48 PM
whitehooptie
07-12-2015 06:10 PM
jl1ne
07-07-2015 08:38 PM
streetbad
Advanced Tech
07-05-2015 10:40 PM
Quick Reply: Horrible Oil Leak.
