Hooker Shories better then stock?
Originally posted by 94GrayV6
60 horsepower from headers? A minimum of 36 hp from LTs? I think you need to be serious! MAYBE you could get 50 hp if you're running a 396 with a huge solid roller cam and massively ported heads.
20-30 from HEaders and 30-60 is very possible don't see what the argument is. Half the restrictions are from the cat on back.
Dude, 60 rwhp from a set of LTs is not going to happen on a stock internal motor. If you have a Supercharger running some decent boost, then going from stock manifolds to LT headers will give a huge gain, but I'm betting not 60 rwhp. Now....on a supercharged car with COMPLETELY stock exhaust from heads back to tips, then yeah, going LT and 3" catback might give you another 50-60 rwhp, but that's pushing it on a stock car.
30 is pretty average for a more expensive set of shorties-600 range
60 is average for the more expensive set of Lt's-1,200 range
average for basic Hookers is around 40 or so-600 range
average for basic shorties is around 20 or so-400 range
Not every manufacturers tubes have the same flow calibrations.
Theres plenty of people on here that could explain this better than I can so I'll leave it at that.
Most of those 60hp 1.2K systems already come as a complete system with the custom Y included that's thier advantage.
Headers are only as good as whats being connected to them...
Originally posted by gb95zconv
Like was said earlier...open up the collectors about 1/4 inch all the way around and youll see around a 15hp gain with the Hooker shorties.
This seems a bit high, but I will do it to mine if you have some sort of before and after dyno proof. However, you are right, at the collector they are more restrictive than I think they should be. That would be the easiest 15 HP I ever picked up...and I am willing to pick it up!
Ben
Another thing to look at with shorties/midlengths is the primary size. Make sure it is 1.75"! My Arizona Speed and Marine midlengths are 1.75" primaries, as well as being built extremely well. They were expensive, but the SOTP gain I felt was really good, and the fit and finish on the headers is great. Not to mention they still let you retain emissions equipment.
I'd say if you don't want LT's, get AS&M's, SLP's or TPIS
I believe when he says 15 hp, he means you'll gain a total of 15 rwhp from going from factory manifolds. Not 15 hp on top of the gain you get from going to the shorties. After looking at that collector on the shorties I used to have, yeah I'd say you could gain an easy 5 on top of the gain you get from just going to the shorties for a total of about 15 rwhp.
If you want shorities get the Edelbrocks TES's just as goos as any mid-lentgh but better. Easy bolton and I mean it. No hit or Mis "MAC" product. Edel Brocks slipped right in hassle free as they described. Only down side is they come with Cheap gaskets so buy coppers.
for a stock motor needing emissions, jet-hot hooker shorties are good. AS&M would be even better if you change cam or heads in Calif
might as well get the Hooker cat-back also for less than $300
i felt a big diff ripping off the stock 94 exhaust system and putting in Hooker shorties, 3" cat, hooker cat back
went from 98-99 in 1/4 to 103-104 mph and i did a 106.1 recently w/ 3.73s, my new homemade ram air scoop and no traction
i'd say that's 20-30 hp
Unless you have emissions to worry about don't bother with the shorties. Just do a search on this board, there is many people who have switched from shorties for LTs and said they felt a huge difference. LTs aren't that expensive either. I got a set of ceramic coated LTs from Jet-hot for like $530 shipped.
stockssn2o
May 25, 2015 08:54 AM
