Hooker Shories better then stock?
Old Nov 18, 2003 | 07:59 PM
BOWTYDE's Avatar
I'm looking for headers that are CA Smog legal because I don't want to mess with it. I know everyone says that shorties aren't very good, but they have to be better then stock right?
Old Nov 18, 2003 | 08:02 PM
94GrayV6's Avatar
Yeah, ANY headers flow better than stock manifolds.
It's not that shorties aren't any good, longtubes are just optimal.
Old Nov 18, 2003 | 08:08 PM
Seal's Avatar
yeah
u'd gain 8-10 from shorties when u gain from 20-30 even close to 40
but shorties are a improvement over stock... (cast manifolds suck)
Old Nov 18, 2003 | 08:09 PM
JoeliusZ28's Avatar
not to jump in on your thread here, but are shorties and/or midlengths considerably easier to install? Do you have plug wire burning problems just as often? thx
Old Nov 18, 2003 | 08:12 PM
Seal's Avatar
it is easier...
find a pic of a LT, and compare a shortie/midlength to it
Old Nov 18, 2003 | 08:19 PM
94GrayV6's Avatar
With shorties and midlengths, there generally aren't as many y-pipe fitment issues as there are with LTs. I'd say go with some MAC midlengths, they come with a y-pipe.
Old Nov 18, 2003 | 08:24 PM
Bud M's Avatar
Hooker shorties give better power than stock manifolds but for best results it helps to modify them a bit. The openings in the collector are a bit smaller than the diameter of the y pipe so people generally open them up a little with a grinder or a dremel. They don't give huge power increases but they do give better performance at mid and high rpms and they keep underhood temps lower.
I have had no plug wire burning problems with mine.
Old Nov 18, 2003 | 08:30 PM
Heatmaker's Avatar
Advanced Member
Originally posted by Seal
yeah
Common be serious. Shorties can get you like 20-30 depending on make longtubes are like 36-60 depending on the make. I think FLP has it on lock.
Old Nov 18, 2003 | 08:32 PM
F Carline 94's Avatar
I think he needs a part with a CA CARB number. I am pretty sure even the mac mids (although it has sensor bungs, egr, etc) are not 50 state.
You could probably use them and find a shop that was cool with having the working fittings in place (and not ask for a number).
I went with the SLPs. Same logic. Gotta be better than stock, gotta be legal. CA SMOG
Sean
Old Nov 18, 2003 | 08:39 PM
Seal's Avatar
ok, so i was a bit conservative
Old Nov 18, 2003 | 08:41 PM
94GrayV6's Avatar
60 horsepower from headers? A minimum of 36 hp from LTs? I think you need to be serious! MAYBE you could get 50 hp if you're running a 396 with a huge solid roller cam and massively ported heads.
Old Nov 18, 2003 | 08:50 PM
speed_demon24's Avatar
Old Nov 18, 2003 | 08:59 PM
gb95zconv's Avatar
Like was said earlier...open up the collectors about 1/4 inch all the way around and youll see around a 15hp gain with the Hooker shorties.
Old Nov 18, 2003 | 09:07 PM
Seal's Avatar
i hope to never live in CA
Old Nov 18, 2003 | 09:09 PM
Bud M's Avatar
Then we'll be careful to never invite you
