Hooker LT woes
Old May 4, 2008 | 08:28 PM
MTBSully's Avatar
Hooker LT woes
Not really, but i am very frustrated. Somebody please help me. I am working on my Hooker LT install on my 95 z28 M6 and im having some trouble. I got the passenger side in w/o jacking up the motor, but the drivers side still wont go in even when i have jacked up the motor 3-4" on that side!! Steering knuckled and oil filter have been removed, and the car is plenty high. WTF is going on? The header just keeps on getting caught up on the K-member. Am i supposed to separate the Drivers side header into two pieces like it is from the factory? You can see where it came in two places. I thought the drivers side was supposed to be easy?
Any tips to getting the front primary disconnected? its rusted on there pretty good.
Old May 4, 2008 | 08:45 PM
Romero155's Avatar
Yea you might have to disengage the primary unfortunatly i think. Try penetrating oil all over that slip fit and give it some light bangs to try and break it loose. Thats all i can think of.
Old May 4, 2008 | 08:56 PM
94 Sunburst formula's Avatar
Heat it up where it is rusted. That how i do it at work and they normally come right apart.
Old May 5, 2008 | 06:18 AM
Don 97 SS's Avatar
Heating the area and then lightly tapping the piece should get it apart. If you don't has access to a torch then try PB Blaster brand penetrating spray. That stuff is pretty amazing and works well.
Old May 5, 2008 | 11:40 AM
MTBSully's Avatar
when i do get it apart it should be easy to slide it back in once the header is in right?
Old May 5, 2008 | 12:37 PM
white97T/A's Avatar
Should be easy to put it back together. If it is rusty just sand the part that slips inside of the other tube a bit and that should help.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Devinfoote87
Jul 30, 2015 09:54 AM
jasonduaine
Apr 1, 2015 08:09 PM
