Hooker LT header install on an LT1/EGR block off paltes
Can you guys give me a link to any good guides to doing a Hooker LT header install on an LT1. I have crawled through the engine bay of my LS1 many times but this is my first LT1 header install and could use a little guidance.
Also where can I get block off plates for the EGR and AIR connections that will no longer be used once the headers are installed. Thanks.
here is a link
this is shoebox tech page, you can find all kinds of cool stuff here including part number for EGR block off plate.
I bought my EGR block off plates from this place: http://www.mycamaroz28.homestead.com/
The guy that I dealt with was a real pleasure to do business with. I received my plates in 2 days after I ordered them.
I don't have much of a write-up but I gots some pics
http://www.bfranker.badz28.com/fbody/exhaustday.htm
what exactly needs to be purchased for a longtube install?
1 o2 sensor extension?
speed tape
which bolts?
question about EGR and AIR, how do you remove them on a stock programmed OBD1 without setting an SES?
speed tape
which bolts?
