Hooker LT header install on an LT1/EGR block off paltes
Old May 2, 2003 | 09:37 PM
Demon SS's Avatar
Can you guys give me a link to any good guides to doing a Hooker LT header install on an LT1. I have crawled through the engine bay of my LS1 many times but this is my first LT1 header install and could use a little guidance.
Also where can I get block off plates for the EGR and AIR connections that will no longer be used once the headers are installed. Thanks.
Old May 2, 2003 | 09:50 PM
revtime's Avatar
here is a link
this is shoebox tech page, you can find all kinds of cool stuff here including part number for EGR block off plate.
Old May 3, 2003 | 08:25 PM
Demon SS's Avatar
ttt
Old May 4, 2003 | 02:08 AM
carlos64030's Avatar
I bought my EGR block off plates from this place: http://www.mycamaroz28.homestead.com/
The guy that I dealt with was a real pleasure to do business with. I received my plates in 2 days after I ordered them.
Old May 4, 2003 | 02:32 AM
Javier97Z28's Avatar
Moderator
just use mine
http://www.zmydust.com/headers
Old May 4, 2003 | 05:45 AM
joeSS97's Avatar
Check Javier's site.Patience is key.Walk away and take breaks when you get frustated.The block off plates can easily be made.Good luck.
Old May 4, 2003 | 07:20 AM
Brent94Z's Avatar
Super Moderator
I don't have much of a write-up but I gots some pics
http://www.bfranker.badz28.com/fbody/exhaustday.htm
Old May 4, 2003 | 07:58 AM
anasazi's Avatar
what exactly needs to be purchased for a longtube install?
1 o2 sensor extension?
speed tape
which bolts?
question about EGR and AIR, how do you remove them on a stock programmed OBD1 without setting an SES?
Old May 4, 2003 | 09:28 AM
Demon SS's Avatar
thanks for all of the info guys, it is much appreciated.
Noenav
Mar 1, 2019 07:38 AM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
