Hooker LT Exhaust leak?
Old Apr 17, 2004 | 12:00 PM
drewstealth's Avatar
I just got my hooker LT's installed. I can here a slight ticking sound now. I know i have a leak somewhere. I'm pretty sure it comes from the #1 primary where it slips on. It looks like a pretty tight fit though. How can i tell to make sure its comeing from there and not from where the headers bolt onto the head?
Also if there is a leak on the #1 primary slip fit will that make me loss any hp?
Old Apr 17, 2004 | 12:17 PM
Wilson's Avatar
Cool
If you have any leaks before the O2 sensors you will lose performance. A quick and easy way to track down header leaks is to use a 1" diameter rubber hose and use it as a probe. Put one end next to your ear and use the other end to probe around the header. When you hit the leaky area you will hear it via the tube. Good luck!
Old Apr 17, 2004 | 04:40 PM
What can i do about that #1 primary leak? Will some high temp RTV work?
Old Apr 18, 2004 | 06:22 AM
97FormulaWS-6's Avatar
It works for some people, others it doesn't...
I've had good luck with the Ultra Copper RTV, and 2-cycle exhaust sealent...
Old Apr 18, 2004 | 07:42 AM
LS1_03's Avatar
Don't worry about it. It won't hurt. After you drive it alot(about a month) and it expanding and contracting due to heat cycles it closes up on its own. Ya'll get excited over the smallest stuff.
I didn't put anything on my slip fit and it sealed up on its own. It just takes many heat cycles.
Old Apr 18, 2004 | 09:42 AM
PatriotTA's Avatar
HERE is a thread about my slip-fit fix. If it is a slight leak, it may seal up by itself, but the best thing to do would be to take it to a muffler shop have have them very slightly expand the end of the #1 primary.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Apr 1, 2015 08:09 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Jan 5, 2015 07:14 PM
