hooker longtube install
Old May 25, 2004 | 03:54 PM
ericz28w's Avatar
i just got done taking all of the old crap out and was wanting some tips or suggestions on how to get the new long tubes in.
what did you guys use to block off the EGR and AIR stuff?
driver side seems easy to get in place but i need some help with passenger side. did you guys jack up engine? let me know
i would really appriciate it.
thanks Eric
Old May 25, 2004 | 04:21 PM
joeSS97's Avatar
For the pass. side,remove the bolt that goes thru the pass, side motor mount and jack it up as high as you can.The header goes in from the bottom.It has to go in almost straight up.Block off plates are easy to make.Use the gaskets for a template.A thin piece of aluminum works great.
Old May 25, 2004 | 05:34 PM
Robbie's Avatar
I tried just jacking up one side but that didnt work too well. It would only raise a little. So I unbolted the other engine mounth and jacked the engine up and they went in with ease. I cant remember which side its been so long ago but one side went in without even having to jack the engine up. But since you gonna have to jack it up anyway you might as well put them both on after you jack it up. Some say you dont have to jack the engine up but its well worth it in my opinion. Makes things much smoother. To block the egr off from the back of the intake manifold I bought some sheet metal from Home Depot and cut some flat templates of the shape of the egr valve and sealed it up with black rtv. Sealed great. Just draw you line on the sheet metal then punch or cut it out with a dremel tool.
Old May 25, 2004 | 09:15 PM
ericz28w's Avatar
how high did you guys have to jack up the engine after you undid the engine mounts
thanks Eric
Old May 25, 2004 | 09:17 PM
Spinner's Avatar
thanks Eric
Who cares, might as well jack it until something hits the cowl. More room to work with
Old May 25, 2004 | 09:22 PM
PatriotTA's Avatar
thanks Eric
This is how high mine was jacked up for the passenger side.
http://www.angelfire.com/punk2/falle...collectors.jpg
Copy and paste into your webbrower for it to work.
Old May 25, 2004 | 09:24 PM
ryaskovic's Avatar
Here's a link to my install write-up (warning, it's BIG):
http://www.bfranker.badz28.com/fbod...ube_install.doc
RobY
95Z28
Nov 18, 2023 07:21 PM
Achilles97
Sep 13, 2002 10:49 AM
dobe
Jul 31, 2002 01:28 PM
Javier97Z28
Jul 24, 2002 08:13 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
