hooker longtube install
i just got done taking all of the old crap out and was wanting some tips or suggestions on how to get the new long tubes in.
what did you guys use to block off the EGR and AIR stuff?
driver side seems easy to get in place but i need some help with passenger side. did you guys jack up engine? let me know
i would really appriciate it.
thanks Eric
thanks Eric
For the pass. side,remove the bolt that goes thru the pass, side motor mount and jack it up as high as you can.The header goes in from the bottom.It has to go in almost straight up.Block off plates are easy to make.Use the gaskets for a template.A thin piece of aluminum works great.
I tried just jacking up one side but that didnt work too well. It would only raise a little. So I unbolted the other engine mounth and jacked the engine up and they went in with ease. I cant remember which side its been so long ago but one side went in without even having to jack the engine up. But since you gonna have to jack it up anyway you might as well put them both on after you jack it up. Some say you dont have to jack the engine up but its well worth it in my opinion. Makes things much smoother. To block the egr off from the back of the intake manifold I bought some sheet metal from Home Depot and cut some flat templates of the shape of the egr valve and sealed it up with black rtv. Sealed great. Just draw you line on the sheet metal then punch or cut it out with a dremel tool.
Originally posted by ericz28w
how high did you guys have to jack up the engine after you undid the engine mounts
thanks Eric
thanks Eric
thanks Eric
thanks Eric
http://www.angelfire.com/punk2/falle...collectors.jpg
Copy and paste into your webbrower for it to work.
Here's a link to my install write-up (warning, it's BIG):
http://www.bfranker.badz28.com/fbod...ube_install.doc
RobY
95Z28
RobY
95Z28
Javier97Z28
Jul 24, 2002 08:13 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
