hooker long tube install
Old May 27, 2004 | 08:53 PM
kyzar24's Avatar
what is th trick to get the drivers side long tube in the pass. is suppose to be th hard 1 but it went on pretty easy th driver side is hitting the motor mount and the tube where you add the last tube on is hitting under th last little piece of the steering rod what the hell
Old May 27, 2004 | 09:01 PM
ericz28w's Avatar
take the bolt out of the engine mount, you might have to jack up the engine a little to get the bolt out, after you get the bolt out jack up the engine as high as you can jack it and then the header will slide right in.
you might have to undo both mounts to get the engine to raise, i did
Old May 27, 2004 | 09:13 PM
kyzar24's Avatar
where did u jack up on it at?
Old May 27, 2004 | 09:16 PM
PatriotTA's Avatar
I put a jack under the bellhousing, but I have an M6. If you have an A4, you might want to jack it under the oil pan or the k-member. You removed your steering linkage already, right?
Old May 27, 2004 | 09:17 PM
kyzar24's Avatar
i tried that and it didnt work either did you go in from the top or the bottom my pass. side went in through the top and it says to go in from the bottom
Old May 27, 2004 | 09:47 PM
ericz28w's Avatar
i went in through the bottom on both sides. did you undo the stering linkage?
you might have to take out the oil filter. and also dont slide in that pipe that comes seperate until you get the header in. it takes some wigglin to get the pipe in but it will fit.
Old May 27, 2004 | 10:25 PM
PatriotTA's Avatar
I removed my steering linkage, oil filter and the heat shield for the abs lines. I did have the slip-fit out, like ericz28w mentioned. Mine slid right in. My passenger one slid right in after I jacked up the motor, but I had to jack it up pretty high. Maybe you aren't jacking the motor up enough? Like take that bolt out of the motor mount and jack the motor up until the car moves. Then you will be good for sure.
Old May 27, 2004 | 10:56 PM
kyzar24's Avatar
i just rebuilt the motor and put it in the motor mount bolts are out and i jacked the motor all the way up and it still doesnt fit i didnt have the pipe on oil filter is off no plugs or wires or anything just doesnt want to fit steering lingage is off too
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
