holley 52mm t/b
Old Apr 11, 2009 | 06:14 PM
93v8clone's Avatar
holley 52mm t/b
i just put one on my car and it is now throwin t.p.s voltage codes .ran all the wires wit a dvom all was good tested the tps all was good also ,so i changed it anyway and still same prob at w.o.t only though ......car idling it is at .70 volts and within spec at w.o.t its 5.2 i dont get it
Old Apr 11, 2009 | 08:30 PM
madhatter's Avatar
I slotted my tps sensor. Used a scan tool to get the right voltage when running. Also had to mess with the idle screw to get the perfect idle RPM. Can't remember the specs, but found them somewhere on here.
Old Apr 11, 2009 | 11:57 PM
93v8clone's Avatar
its really pissin me off ,i took it back out shifts real funny and at w.o.t surges like hell at times and other it dont i dont get it in the a.m im runnin on the solus at work and see what its really doin cause its annoying and im sure it aint good
Old Apr 12, 2009 | 08:39 AM
5.2V is too high at WOT. The code sets when it goes over 4.9V. The PCM is supposed to supply 5.0V to the sensor. Check voltage between the black and gray wires. If the PCM is supplying a higher than normal voltage, you may have to slot the TPS sensor screw holes so you can rotate it and lower the voltage until the signal voltage (blue wire) does not exceed 4.9V.
In most LT1's, the WOT voltage is typically about 4.0V above the closed throttle voltage.
Old Apr 12, 2009 | 08:45 AM
93v8clone's Avatar
ahhhh ok ill try that and report back, what should i set the base "idle # at? right now its at .70
Old Apr 12, 2009 | 08:54 AM
The LT1 PCM accepts any closed throttle voltage beteen 0.20-0.90V, and sets that as the 0% throttle baseline as soon as the key it turned to on. Its not critical. Some people claim there is an advantage in getting it between 0.50-0.67V. But I've never seen any difference. Most of the unmolested factory TB/TPS readings are about 0.67V. Just rotate it slowly -0.10V at a time, tighten down the bolts, and see where the WOT voltage ends up. Make sure the blades are fully returning to the closed position.
Old Apr 13, 2009 | 09:13 PM
93v8clone's Avatar
injuneer thank you ,i got it. my idle is now at .36 volts and my w.o.t is now 4.76 volts i really appreciate it .......now i just gotta find my surging problem at w.o.t power feels wavy still but it was like that before t/b
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
colts0455
Sep 2, 2015 12:41 PM
