Hitting Rev too soon?!?
Old Jul 11, 2006 | 03:44 PM
JAG05's Avatar
My car has started hitting the rev limiter too soon its hits it now at around 5-5200. It only does this at WOT, if a pull it down in gear and run the RPMs up it wont do it. The tranmation doesnt sshift enough until i let off. Could this be the TPS or what?
Old Jul 11, 2006 | 03:50 PM
buzz12586's Avatar
Re: Hitting Rev too soon?!?
Your tach could be way off????
Old Jul 11, 2006 | 03:51 PM
JAG05's Avatar
But that wouldnt cause it not to shift right.
Old Jul 11, 2006 | 04:03 PM
ajschult's Avatar
i think what buzz is saying is that if your tack is way off, it is in fact hitting the rev limiter at a much higher rpm (like it should be). Now if you can tell by feel that it isnt rapping out like it used to then you seem to have a problem.
Old Jul 11, 2006 | 10:29 PM
JAG05's Avatar
The tech isnt off it still idles at the same RPMs and runs down the road at the same RPMs.
Old Jul 11, 2006 | 10:38 PM
LT1Squirrel's Avatar
that doesnt mean a thing...just like speedos there are designed to be more accurate on the lower side since thats where they'll spend the majority of their time...the only way to find out your real rpm is w/ a quality tach or logging
Old Jul 11, 2006 | 10:56 PM
JAG05's Avatar
would the tech being off cause the car to hit the rev and not shift though??
Old Jul 11, 2006 | 11:30 PM
sbs's Avatar
sbs
The tach being off would have nothing to do with an A4 hitting the rev limiter.
Started doing it out of the blue, or have you done work on it recently?
Old Jul 12, 2006 | 10:29 AM
JAG05's Avatar
Just out of the blue I put a set of underdrives on it but after that it did fine thats the last thing i did to it, other than changing the oil and uses a thicker weight.
Old Jul 12, 2006 | 01:21 PM
sbs's Avatar
sbs
Just to be clear - if you accelerate at part-throttle, you are able to get to redline in 1st, but at WOT it stops accelerating around 5200 rpm?
If that's the case, it sounds more like an engine problem than a tranny problem.
Just to cover the basics - enough ATF? fresh ATF?
Old Jul 12, 2006 | 03:04 PM
JAG05's Avatar
Ok today i just held the gas down and its NOT hitting the rev it is knocking in the engine sounds like its hitting the rev buts a knock because the rpms climb but much slower. Its not the trans cause that was my first thought and i took it to a trans shop and they said the trans was fine it was something in the engine. So i recently change the wieght of oil in my car could this becauseing me to float a valve because ive noticed one of my vavles has been ticking alot more lately. I run 93 octane in it so its not the gas.
Old Jul 12, 2006 | 03:06 PM
cause4panic's Avatar
Dead opti/fuel pump
Old Jul 12, 2006 | 03:09 PM
JAG05's Avatar
opti was replaced six months ago. ANd would the fuel pump work fine at low rpms and stop at high?
Old Jul 15, 2006 | 11:59 AM
JAG05's Avatar
Could the knocking be a lose timing chain getting out of timming in upper RPMs?
Jeff1904
Jun 5, 2016 05:00 PM
WobblySausage
Oct 7, 2015 10:09 AM
Aaront810
Sep 11, 2015 11:24 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
