Higher compression = colder or hotter spark plugs?
Old Apr 20, 2005 | 07:53 PM
Pasky's Avatar
Static compression is 11.54:1
Dynamic is in the 8.5x range
Can someone recommend a spark plug?
Old Apr 20, 2005 | 11:57 PM
Pasky's Avatar
Re: Higher compression = colder or hotter spark plugs?
Old Apr 20, 2005 | 11:58 PM
oneslowz28's Avatar
colder
Old Apr 21, 2005 | 12:05 AM
disco192's Avatar
TR6 or autolite 104 (maybe 102)
Old Apr 21, 2005 | 12:06 AM
Pasky's Avatar
Thanks.
Old Apr 21, 2005 | 04:16 PM
Fbody1's Avatar
what will happen if you use the stock heat range? will you get some spark knock or something?
Old Apr 21, 2005 | 04:38 PM
Formula03's Avatar
No, you just wont get optimum results.
Old Apr 21, 2005 | 05:06 PM
Mindgame's Avatar
Rule of thumb = 1 step colder for every 75hp increase.
Try a step colder and see how they look after a week or so of driving. If they carbon up then you need to go hotter. The correct heat range will self clean.
-Mindgame
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
