High volume oil pump at what clearances?
Old Jul 3, 2008 | 05:35 PM
johnnyb's Avatar
I checked the clearances on my 355 and the mains are .0025 and the rods are .0027. The guy at the machine shop told me today to run 20w-50 with a hv oil pump. Is the HV oil pump necessary with the clearances i have? I have the stock pan and i have heard of horror stories with the HV pump. so it would be real nice if it wasnt necessary to get the high volume pump and a larger pan
Old Jul 3, 2008 | 06:38 PM
Thicker oil and an HV pump sound like a recipie for a stripped pump drive gear. You already know not to run a stock pan with the HV pump. i don't think your clearances are that far out, but I also do not build engines for a living. Maybe some people more qualified will reply.
Old Jul 3, 2008 | 06:48 PM
maverickmk's Avatar
stock pump if you stay with the stock pan, if you have to have a HV pump then get a larger pan and I would not go any thicker than 10W30, like shoebox said "it's a recipe for disaster" - but that's just my opinion - do a search on high volume oil pump and you will find a plethora of information
Old Jul 3, 2008 | 10:18 PM
johnnyb's Avatar
I know not to use the hv pump with the stock pan. But is 20w-50 with the regular pump going to be enough with the clearances i have?
Old Jul 3, 2008 | 11:02 PM
Stock pump.... with some "blueprinting", may be the best solution:
http://www.gofastnews.com/board/tech...ower-mods.html
Old Jul 3, 2008 | 11:25 PM
rskrause's Avatar
Moderator
Stock pump, stock pan, 10W-30 will be fine unless i you are using a big-time power adder.
Rich
Old Jul 3, 2008 | 11:44 PM
jclark311's Avatar
I have pretty much the same setup, use a stock pump with the GM White Spring, weld the pickup tube on, and run 10w30, when i start mine i have 50lbs of oil pressure when its hot, at idle i still have 25.
Old Jul 4, 2008 | 11:01 AM
johnnyb's Avatar
thanks alot everyone!
Old Jul 4, 2008 | 12:06 PM
marshall93z's Avatar
Stock pump with "white" spring... .003 on the mains and .0022-.0025 on the rods. ~30 psi hot at idle with 10w-40. Getting ready to switch to 10w-30, so probably around 20psi then.
Old Jul 18, 2008 | 02:28 AM
RACEON's Avatar
Mellings M55 (circa 2001) 5/8 tube, stock pan, 5W-40 with Orange Canton spring. 80 psi cold (Hawaii Cold, 80 degrees) 40-50 psi at idle warm. This is a engine with very similar clearances.
Changing spring to Mellings Yellow. See what happens next week.
Old Jul 18, 2008 | 08:51 AM
The_Bishop's Avatar
Why does everyone insist on larger than stock clearances? It's simply not necessary.
Old Jul 18, 2008 | 11:07 AM
maverickmk's Avatar
so they can run a HV pump?
Old Jul 18, 2008 | 12:29 PM
96capricemgr's Avatar
One of the Impala guys just had the drive strip, he was using a melling 10552, this is listed as being slightly higher voume than stock, but I am sure that is not compared to a stock LT1 pump, so I am not sure if we should call it "HV" or not.
Old Jul 18, 2008 | 12:53 PM
rskrause's Avatar
Moderator
Some engine builders like bigger clearances for very hi-po motors. The idea is that there is more deflection and that a thicker oil film will minimize metal to metal contact under these circumstances. That's they way my machine shop does it and it makes sense to me. I can't say if it's true or not though.
Rich
Old Jul 18, 2008 | 01:02 PM
87Aerocoupe's Avatar
Is there any solution to the cracked and striped oil pump drives, is there a billet or stronger alternative?
