high volume oil pump + stock pan, any problems?
Old May 12, 2006 | 08:25 PM
  #16
RCF925's Avatar
Re: high volume oil pump + stock pan, any problems?
Okay for arguments sake, My oil pump pick up is roughly .375 off the bottom of the pan so in order to suck it dry I would have to have roughly 5 quarts of oil up top in the rocker and lifter valley. My pump also maxes out at 60 psi at 2400 rpms so the higher I rev won't change my oil pressure .I just don't see a hv pump pumping that much oil up top and overwhelming the drains back down. There has to be some other reason for losing oil pressure as stated before like no windage tray or your oil pump pick-up set to close to the bottom of the pan or to far away.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
