High volume oil pump question(Do you remove the top of the pump to change the spring)
I have a high volume, high pressure oil pump , and I just want to change the spring to lower the pressure . A lower pressure spring came with the pump. Do I just take the top of the pump off (remove the 4 bolts) to do this?
Thanks.
Thanks.
Originally posted by 97 RedSS
I believe its just a pin that holds the spring in there..just remove the pin, change spring, and reinsert the pin..
Cody
Cody
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
