high volume oil pump + elec. water pump
Old Feb 11, 2004 | 08:07 PM
FacelessZ's Avatar
Is this a good combination to go with during a cam install? I know the high volume oil pump is typically installed with a rebuild, but would I see some better drivability and possibly gains?
Ive heard that going with a high volume oil pump can give comparable gains to an electric water pump...is this true?
Thanks!
-Doug
Old Feb 11, 2004 | 08:17 PM
dnz28's Avatar
just stick with h2o pump changing a oil pump in the car is the biggest pita. save it for a rebuild.
Old Feb 11, 2004 | 08:19 PM
Not sure how an HV oil pump (having bigger rotors and mass to turn) will give power gains. I'm open to explanation.
Old Feb 11, 2004 | 08:21 PM
FacelessZ's Avatar
If I knew I'd explain. Like I said in the initial post, I just heard that it did...if it doesn't then it doesn't...
Old Feb 11, 2004 | 11:35 PM
Most experienced engine builders recommend a stock volume pump with a higher pressure relief spring for extended RPM operation. I've never heard of changing to a HV oil pump to save HP. It would have just the opposite effect.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
