High temp RVT sealant.
Old Nov 27, 2005 | 03:18 PM
LT1 POWR's Avatar
Should i use some high temp RVT sealant on my felpro header gaskets that i will be installing on my car shortly. I will also be deleting EGR and AIR at the same time. Should i use that stuff on the aluminum block off plates on the back of the manifold and #8 primary tube. Also should i also use it on the threads for the AIR plugs. Let me know. Thanks.
Old Nov 27, 2005 | 03:25 PM
Mindgame's Avatar
Re: High temp RVT sealant.
Whatever you use it should read "O2 sensor safe".
If you're using the Fel Pro composite gaskets then you shouldn't need any RTV. If the block offs don't have a gasket, then yes I'd put a bead on there. Let the stuff take a slight set before you start tightening everything up.
-Mindgame
Old Nov 27, 2005 | 03:26 PM
atljar's Avatar
Copper RTV
I would use it on the block off plates, and the AIR/EGR fittings. Leave the rest of it alone.
If you do decide to use it for sealing the flange to the head, dont use a gasket with it. Put a 3/8" bead around the port and bolt in hand tight. Then let it set up for 15-20 min and do your final tightening
EDIT: MG beat me to it
Old Nov 27, 2005 | 04:17 PM
Tanker Don's Avatar
I just finished an install of SLP shorties with the FelPro gaskets and Breslin locking bolts. I had leaks at first, even though they claim not to back out. All but 2 of them loosened up. I re-torqued and locked them and they seem to be holding fine, and I don't detect any leaks. I didn't use any RTV on the Felpro gaskets. I did use some Permatex Red Hi-Temp RTV for sealing the EGR pipe gasket... would suggest you use some on any block off plates you make... not sure you'll need it for the AIR fittings... mine don't leak... but they are easy to get to if you later decide they need some RTV. Good luck!
Old Nov 27, 2005 | 09:30 PM
Lonnie Pavtis's Avatar
Use Permatex Ultra Copper. It is the highest temp rated Permatex brand. The other brands I've tried do not work as well.
I use this on all header & exhaust connections & I never had a leak yet.
Old Nov 28, 2005 | 02:39 PM
WhyHelloOfficer's Avatar
Ultra Copper all the way. Used Stage 8 Locking Bolts and I've had to crank them down a few times -- but everything else is great.
Old Nov 28, 2005 | 03:18 PM
Evil Eric's Avatar
Ditto. Works great on water pump gaskets to.
Old Nov 28, 2005 | 03:24 PM
96TurboTA's Avatar
I agree. I used it on my turbo hot side and never had any leaks.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Midnight_Z
Feb 16, 2016 09:36 PM
May 21, 2015 01:04 PM
