high temp at idle
Old Mar 30, 2007 | 04:01 PM
oneclean97z's Avatar
high temp at idle
ive searched but haven't really found an answer im looking for, if i am sitting at idle for a little bit my temp gradually rises up to just before the redline, i know this isn't normal. i just had a new waterpump put on with the opti about a week ago along with a 160 stat. bleed the system and everytime i check the coolant level its fine. i can hear it bubbling and such inside the radiator after i shut the motor off while its hot. runs at about 170ish on the highway or from about 40mph and above does anybody have any ideas?
Old Mar 30, 2007 | 04:02 PM
LiENUS's Avatar
Fans working ok and is the air dam intact?
Old Mar 30, 2007 | 04:47 PM
OBE1 95Z28's Avatar
What ratio of coolant do you have? How old is the radiator pressure cap (they've been known to go bad).
Old Apr 2, 2007 | 01:32 PM
fans come on at proper temp, both radiator cap and reservoir are fine, and coolant/water mixture is perfect. level is good too and have bleed it
Old Apr 2, 2007 | 07:19 PM
Mu2LoW's Avatar
I thought the PCM had to be adjusted for the fans to come on earlier with the 160 stat? Anyways, Run a manual fan switch - you'll be alot happier.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Midnight_Z
Feb 16, 2016 09:36 PM
lt1matt
Mar 21, 2015 07:35 PM
