High Stall no 1-2 shift
Old Mar 26, 2004 | 11:38 AM
chrism400's Avatar
If I were to go with a 3200 stall, will OBD1 do the old no 1-2 shift without programming? Thanks,
Chris
Old Mar 26, 2004 | 11:45 AM
justahoe's Avatar
I went with a 3000 and have no problems.
Old Mar 26, 2004 | 12:05 PM
chrism400's Avatar
If you don't mind me asking, what does your combo run? With n2o?
Old Mar 26, 2004 | 01:51 PM
justahoe's Avatar
I don't know yet I just put most of it in this winter. I'm hoping for a low 12 w/ a 100 shot.
Old Mar 26, 2004 | 02:08 PM
chrism400's Avatar
Is your conv a lock-up? How does it act on the street?
Old Mar 27, 2004 | 08:18 AM
justahoe's Avatar
My conv acts alot like the orginal honestly, just stalls out a higher. Makes a little rough to hook up under full throttle off the line and through most of second, on street tires.
Old Mar 27, 2004 | 08:31 AM
97Z-M6's Avatar
Re: High Stall no 1-2 shift
Chris
most likey so.
some get away with a 3000 but a 3200 will probably give you trouble. but there is a programming fix for it.
Old Mar 27, 2004 | 09:29 AM
RamAir95TA's Avatar
I didn't have a chance with my 3600...
Bryan fixed that for me though.
Old Mar 27, 2004 | 09:58 AM
flyinZ's Avatar
I have a 3200 Midwest and I had the problem...but a buddy of mine fixed that problem also..."Doom Master" did that for me.
Old Mar 27, 2004 | 11:44 AM
Loadre's Avatar
My 3200 Edge with a 2.5 STR gave me no problems. Can't wait to get to the track. Deep 12s are here since I finally got some DRs.
Old Mar 27, 2004 | 12:08 PM
worak's Avatar
i had a 3000 stall from tci and it wouldnt lock up, they exchanged it out 3 times still the same problem. i got fed up and did a m6 conversion. its weird how some guys are fine and others have problems
Old Mar 27, 2004 | 01:14 PM
Loadre's Avatar
Not locking up (ie - overdrive) and no 1-2 shift are different problems.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
Jan 12, 2015 05:44 PM
RichardZ SS
Aug 3, 2002 12:26 PM
