High Stall no 1-2 shift
Re: High Stall no 1-2 shift
Originally posted by chrism400
If I were to go with a 3200 stall, will OBD1 do the old no 1-2 shift without programming? Thanks,
Chris
Chris
most likey so.
some get away with a 3000 but a 3200 will probably give you trouble. but there is a programming fix for it.
i had a 3000 stall from tci and it wouldnt lock up, they exchanged it out 3 times still the same problem. i got fed up and did a m6 conversion. its weird how some guys are fine and others have problems
carguyshu
Jan 22, 2017 11:19 AM
