High Speed Misfire
Old Oct 24, 2006 | 10:08 AM
Red95M6Z28's Avatar
High Speed Misfire
This is very strange.....
Car details: 1994 M6 Z28 Vert 130k miles
When driving full throttle 1st through 4th the car runs outstanding. Once I hit 5th gear it stumbles and misfires badly! It continues into 6th gear. If I go back to 4th after slowing down it will accelerate 100% again.
Any thoughts on this?
Old Oct 24, 2006 | 11:18 AM
ZFan88's Avatar
Re: High Speed Misfire
What are your mods? Any wires arcing? I have headers and just fixed this exact problem yesterday. Does your SES light flash at you once you're in 5th?
Old Oct 24, 2006 | 11:21 AM
Red95M6Z28's Avatar
The car does have headers but I just had it at the mechanic and he fixed some loose connections but the plug wires were fine.
The SES light is on all the time due to a o2 sensor but no it never flashes.
Old Oct 24, 2006 | 11:23 AM
ZFan88's Avatar
So if the plug wires are probably fine, then that leaves you with what to cause a misfire? Opti or bad coil? Have those been checked out? Timing?
Old Nov 4, 2006 | 10:00 AM
Red95M6Z28's Avatar
It appears I have a fuel cutoff at 115mph. or thats my speed limiter?
Old Nov 4, 2006 | 10:45 AM
1 slo 6's Avatar
i believe a bad o2 can cause that problem....
AdsoYo
May 2, 2018 03:21 AM
Klypto
Mar 23, 2016 09:05 AM
PCLZ28
Dec 24, 2015 05:19 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
