High rpm stutter (EGR)????
Old Apr 14, 2009 | 09:37 PM
GMH94Z28's Avatar
Tonight i removed the egr valve, egr exhaust gas feed pipe and i capped the vacuum feed. I installed some egr block off plates and I took it out for a drive and got on it and now i have a high rpm miss. It pulls smooth all the way up the rpm band until about 6000 or so. Could this be related at all? That is the only thing that i have changed. Thanks in advance
Old Apr 14, 2009 | 11:35 PM
The EGR system does not operate above 3,500RPM, so its not likely that removing it affected high RPM operation.
How well did you seal the blockoff plates?
Old Apr 15, 2009 | 07:49 AM
GMH94Z28's Avatar
With the gaskets that came with the plates. Should i use some rtv on them?
Old Apr 15, 2009 | 09:22 PM
GMH94Z28's Avatar
It turned out to be my coil. I replaced it with a new one and the problem is gone.
Old Apr 16, 2009 | 12:12 AM
93FIRETURD's Avatar
started throwing parts at it?
Old Apr 16, 2009 | 07:58 AM
GMH94Z28's Avatar
Well i tested it using http://shbox.com/1/coil_testing.jpg
and mine was reading 9.54 to 10.11. But it was the original coil so i figured it wouldnt hurt to replace it.
timmy39120
May 8, 2015 11:41 AM
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
97SSdude
Dec 31, 2014 07:43 PM
