Is there a 2 piece timing cover that'll work?
Old Apr 16, 2009 | 12:08 AM
LT1 POWR's Avatar
I'm building a 383 with a MSD opti, an electric water pump, and a cloyes double timing chain and was wondering if there is a 2 piece timing cover that will work for my application or if you'd even suggest a 2 piece timing cover?
Old Apr 16, 2009 | 04:42 AM
RamAir95TA's Avatar
Why do you need a two-piece cover? Lots of guys (including myself) run identical set-ups using the stock cover.
Old Apr 16, 2009 | 08:31 AM
LT1 POWR's Avatar
So you can adjust timing without dropping the oil pan. I don't know if there is enough room to change out the cam without engine removal, but a 2 piece would also allow you to do that.
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
