High RPM Miss
Old Mar 9, 2004 | 10:07 AM
wes95_z28's Avatar
High RPM Miss
Alright heres the deal, recently my car has been missing in the high RPMs usually around 5500 RPMs ( I have my limiter at 6000) and then the miss started occuring at a lower and lower RPM, now it misses at around 4000 and feels like it almost on a soft touch rev limiter when it is missing it will eventually go a head and pull on up to 6 but then again sometimes it wont. I believe that it is the optispark starting to go out but i have heard that the start missing at low RPMs rather than high RPMs, another thing i thought it might be is the fuel filter i have a A/F ratio guage and it tends to fluctuate a small amount towards the lean side when the miss starts occuring, i would have thought if im gettting the correct amount of fuel and the cylinder is just not firing that the a/f guage would show a richer than normal state
Old Mar 9, 2004 | 10:13 AM
Mr_Bond's Avatar
Sounds like the opti-spark. Check you plug wires first to make sure none are burnt or loose.
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
