High output alternator for LT-1
Old Jun 12, 2003 | 12:05 PM
1st and goal's Avatar
Question High output alternator for LT-1
Who makes a high output alternator for an LT-1?
With all the stuff I'm running, I need a little more sack out of my alternator.
Marc
Old Jun 12, 2003 | 12:11 PM
chasmanz28's Avatar
Re: High output alternator for LT-1
Marc
check ebay they sell them 129 bucks
Old Jun 12, 2003 | 12:13 PM
Izod's Avatar
well, first i doubt you need a h.o. alternator. first thing i'd do is get a dry cell battery, like an optima or the interstate red/blue tops (which are GREAT batteries). or get a cap if its the subs. and finally if you really think u need an h.o. last i saw summit had some, but u never know how summit part match up...
Old Jun 12, 2003 | 12:16 PM
Izod's Avatar
LOL nm, i just saw ur car. nice car bro. yeah summit has em, or like 130ish i THINK.
Old Jun 12, 2003 | 02:00 PM
I found this, but am just looking for other options and to see what other people are using when they require a little more voltage / amps.
http://www.kilbyenterprises.com/mean_green.htm
Marc
Old Jun 12, 2003 | 02:27 PM
LWillmann's Avatar
www.mralternator.com is where my 200 amp unit came from.
Old Jun 12, 2003 | 04:08 PM
97FormulaWS-6's Avatar
I got mine off Ebay for $200, I've had it for over 2 years, and it works flawlessly.. it's supplying my system of ~2Kwrms nicely.
If this is due to a system... a Cap/Battery is a band-aid for a weak charging system... unliks what other's have said.
I'm running 2 Farad's worth of caps, a 200amp alternator, and even still I get a twitch every once in a while in my Volt gauge.
Old Jun 12, 2003 | 04:12 PM
Gripenfelter's Avatar
Upgrade the alternator cable running from the alternator to the positive battery terminal to a 4 guage or 1 guage.
Add a new 4 guage or 1 guage ground wire from your strut tower nut to the negative terminal on your battery.
That should bring you up 1/2 to 3/4 of a notch.
Old Jun 13, 2003 | 11:30 AM
Izod's Avatar
4 gauge should suffice
Old Jun 17, 2003 | 03:43 PM
I ended up ordering this one as it has 220 amps
Marc
Old Jun 17, 2003 | 04:04 PM
$335??
What kind of warranty does it have?
Let us know how it works out. Probably twice as heavy as the stocker.
Old Jun 17, 2003 | 04:33 PM
Josh-'04 GTO's Avatar
Wow! That should do the job... Lot of cash for an alternator though.
Old Jun 17, 2003 | 06:25 PM
snorkelface's Avatar
Question
Question about this. I did this upgrade, but found it basically impossible to to add the ring terminal, and still have the battery terminal still be able to thread into the battery. The terminal bolt just wasn't long enough with the rubber cover over the battery terminals. What did you guys do?
Old Jun 17, 2003 | 06:37 PM
I didn't use terminal bolts at all.
PM me tomorrow and I'll send you pics of my setup.
Old Jun 17, 2003 | 06:38 PM
Will do, thanks.
