High Idle.....
Old Jul 14, 2003 | 12:06 PM
  #16
slmdgmc's Avatar
the idle went down more than half with blocking off the iac hole, so i would say that would be the problem. I took the iac out and measured it and measured how far the hole was in the TB, and its not even close to the hole, so its gotta be frozen open.
Old Jul 14, 2003 | 01:39 PM
  #17
Hotwire's Avatar
Talking SWEET!!!
Grab ya a new one and let us know!!!
Old Jul 15, 2003 | 11:21 AM
  #18
slmdgmc's Avatar
Installed new IAC this morning, crunk it up and it idled at 1100......GRR i started freaking out, then after 10 secs it went to about 750-800. perfect..... crunk it back up, and it idles right at 750rpms. MmMmM I love lumpy cams....
Old Jul 15, 2003 | 01:38 PM
  #19
Hotwire's Avatar
ya owe me a wav file of that cam!!!!
good luck with it man, glad ya nailed it!
I just hooked up my performance shift option and park / neutral safety switch last night, going to drive it around tonight , let you know if there is any difference. I really think the p/n switch just tells the motor what to idle at, and would trigger the relay to keep the starter from kicking, but i'm sure you went around that like i did, my motor didn't come w/ the fuse/relay box.
have fun!!
Old Jul 15, 2003 | 03:58 PM
  #20
slmdgmc's Avatar
I will post some videos and some files on my sounddomain page sometime soon.
Actually I have the PRNDL switch all wired in with the starter and it all works with the lockout features and everything. I didnt have a wire off the truck that was the PNP wire, so that's why I didnt hook it up.
Right now the shifting seems off on mine, but I might just be low on fluid still since I blew a line and it puked alot out. Let me know if the performance shift does anything, but I have a custom tuned computer from pcmforless, so I dont know if it would override it or not?
Old Jul 15, 2003 | 05:51 PM
  #21
Hotwire's Avatar
it may put out a better shift than what they tuned in. If you pulled those wires into the truck I can tell you how to hook them up, it's really simple. I would have to look up the wire locations, but it's a light and dark blue wire. one is setup on a momentary push button to ground, when you push it it tells the pcm to switch over, then the other wire hooks to a led and resistor to +12v so it lights up when in performance mode. I'll take pics of my setup, it's pretty cool.
all the pnp wire does is go to ground when you are in park or neutral, that's it. you can splice it into the stock truck harness w/ no worries. It'll just idle the truck up a little when in park vs when in gear.
i'm going out there now. just got a lt1 file w/ hypertech tuning installed, going to run it on the beast to see what it does.
colts0455
Sep 4, 2015 01:41 PM
FredM
Aug 14, 2015 01:49 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
mrwz28
Jul 8, 2015 09:11 PM
