High Flow Cats vs. Stock
Old May 29, 2015 | 09:07 AM
Beave2780's Avatar
What is the gain of replacing stock cats?
1996 Dual Cat LT1
Old May 29, 2015 | 11:16 AM
Chimera96's Avatar
Re: High Flow Cats vs. Stock
"if" your stock CATS are clogged than replacing them will increase exhaust flow....but simply replacing the stock CATS with aftermarket ones will not really yield much if any gain in HP
The stock CATS are not any more restrictive that replacement CATS
Old May 29, 2015 | 04:31 PM
John Lingenfelter was building and selling an EPA certified 383 LT1 back in the mid-90's, with the stock single cat configuration. At the 400+HP level, he claimed less than 5HP loss. At stock HP levels, it would be significantly less than that.
Depending on whether your state enforces the Federal rules for catalytic converters, you may not be able to replace them unless they are certified to be defective. And if you are in California, you can't use any cat that isn't specifically certified by CARB as a replacement for your stock cats.
Some things are better left alone.
Old Jun 1, 2015 | 08:19 AM
Beave2780's Avatar
Wow that's crazy. Well about removing the (2) Cats all in general.
HectorM52
Jun 23, 2016 08:42 PM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
