High compression, what starter?
Old Dec 22, 2007 | 11:45 AM
mdacton's Avatar
What starter you guys running?
My alt/starter guy went throught this one(stock) and said it was in good shape and should work fine.
Well it will hardly turn the engine over at all, have used 2 batteries, and also done it with the charger hooked up....
stroker motor with around 14 so do I need a starter or what?
Also with the fire off when I spin it over it will barley turn it
Old Dec 22, 2007 | 12:10 PM
96capricemgr's Avatar
I suppose this has stopped you from getting a cranking compression reading??
A stock L99 starter turned over my motor just fine with 230psi cranking compression. The L99 starters are the old style BIG heavy beasts without gear reduction. I used it till like 170K miles when I broke the solenoid tightening a wire.
Have you upgraded the wiring? a more powerful starter wont help if the wiring is stock small gauge.
Old Dec 22, 2007 | 12:33 PM
nickp's Avatar
my friend rebuilds starters & alternaters for a living, he said the lt1 vettes have much better starters. you could possibly look into that.
Old Dec 22, 2007 | 12:45 PM
mdacton's Avatar
I have 0ga wire going to a ford solenoid then a 18" pc. of 0ga going to the starter and the GM solenoid is jumped.
It turns slow but but it started the other day....now it won't spin fast enough
Napa shows the vette starter as the same part number.....You must mean a LT4 gran sport starter......If I need to go that route I wll just get a racing starter. I was hoping this one would work.....I'm on a shoestring here.
My cranking compression is not going to be much....I don't think, b/c the cam
I have one of those old big truck starters but it won't fit, no way for it to clear the header
Old Dec 22, 2007 | 12:46 PM
rock1501's Avatar
I use a digital7 ignition box to retard the startup timing(15 degrees or so)
starts up very easy with the stock starter
however my compression is only 13.6:1
Old Dec 22, 2007 | 12:51 PM
mdacton's Avatar
well I'm getting the same thing with no ignition at all.......so maybe I need to see how many amps I'm pulling, B/C its the same either way
FredM
May 28, 2015 04:28 PM
lt1matt
Mar 21, 2015 07:35 PM
pimpss96
Feb 12, 2015 01:28 PM
Jeff1904
Jan 3, 2015 12:00 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
