high compression LT1 guys
Old Aug 18, 2008 | 11:17 PM
rock1501's Avatar
What are you using for starter motors?I just blew apart my 3rd stock one
compression is 13.7
Old Aug 19, 2008 | 10:15 AM
95Blackhawk's Avatar
I am using an LT4 starter for my 12.4 CR motor.
Old Aug 20, 2008 | 07:01 PM
Projectz28's Avatar
Moderator
same here. 12.5 and LT4 starter no probelms.
Old Aug 20, 2008 | 09:28 PM
jpack24's Avatar
I had a custom one made. My original one went after two start ups. I also lowered the timing at start up and now it starts like a stock compression car. I had a optima red top and with the old starter it would crank really, really slow and then fire. Starter was a lt4. I payed a guy local to me 120 for the new custom one. They use the same style in his all out race car, and has actually cranked it to pull it onto a trailer....lol
Old Aug 22, 2008 | 11:10 AM
rock1501's Avatar
hey you guys think this one will fit?
http://www.jegs.com/i/JEGS/555/10021/10002/-1
Old Aug 22, 2008 | 12:26 PM
Projectz28's Avatar
Moderator
Hard to say but it it will bolt up assuming nothing gets in the way. Might be a tight fit with the headers/pan depending on what you have. Try it and if it doesnt fit you can always send it back.
Old Aug 22, 2008 | 12:41 PM
rock1501's Avatar
thats the thing these kook headers take up alot of space pan is a moroso 7 quart.
maybe I should try something a bit smaller if I can find one
Old Aug 22, 2008 | 12:44 PM
SS MPSTR's Avatar
Same here.
Old Aug 22, 2008 | 05:21 PM
Projectz28's Avatar
Moderator
thats why I say maybe. It would probably clear the pan, headers you got a 50/50 shot.
Smaller also means weaker (less hp and cranking power)
Old Aug 22, 2008 | 07:03 PM
<Puck>'s Avatar
Not neccesarily. The strength of a starter depends on its gearing, not engine size. Even a tiny little DC engine can be decievingly "torquey" with the right gear reduction.
Old Aug 22, 2008 | 07:33 PM
Projectz28's Avatar
Moderator
You are right. But when it comes to starters to make them smaller they use smaller motors/solenoids with the same grear to make it fit in a smaller package. Not 100% true for every one but generally what I have seen.
Old Aug 22, 2008 | 08:00 PM
mdacton's Avatar
stock LT1 starter.
I kill the fire when I turn it over then as soonm as I cut the ignition on it fires up.
Never had any problems and mine is pretty high, could be the camshaft though.
Old Aug 23, 2008 | 07:34 PM
sn8ke eatr's Avatar
not exactly high but 11.27 using the stock starter
Old Aug 24, 2008 | 07:27 AM
mdacton's Avatar
Mine is around 14, Yesterday it did fine.....
How are you guys starters hooked up?
I had a bunch of problems until I got rid of the relay and went to a ford solenoid. Its a damned shame everytime I have to fix something I swap on ford parts
Old Aug 24, 2008 | 10:41 AM
rock1501's Avatar
this is what it has been doing
I dont think I want to take a 50/50 chance maybe I will buy 2 used stock ones that way I have a backup if it goes at the track
http://www.flickr.com/photos/1551097...06855/sizes/l/
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
heavenly_six
Dec 10, 2014 12:23 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Red97LT1
Aug 7, 2002 05:45 PM
