high compression 396 spark plugs
just doing this for help if someone will need it in the future
i used autolite racing 473 it stopped my dettination and now my car shifts rather then breaks up
Re: high compression 396 spark plugs
Originally Posted by amean94ta
396 ci, 13.6:1 compression, cc306, ported lt1 castings, int 281 ex 230,
I am rumming 13/1 with no problem on 92 octane,but my DCR is below 9.0.
If ya got detination ya need a tune or my special trick.
Give up the rest of the cam spects and I can tell ya.
I know its too much for pump gas.
I run vp 111 my static is 14.1 i made this post not for help but to help others if they end up not knowing what plug to start off with a similer combo
I rember you had something special what you running these days?
its a off the shelf cc306 with 112 lobe seperation, i fixed the detination with the listed plugs thats what i am saying, tune credit goes to bryan herter
but if you know of a nice solid roller combo for my heads i would like to hear it lol
Same old 383-- can't afford another one and business hasn't been real good lately,Sooo.
If you don't mind me asking, where did you get the plugs? Can you pick them up at the local auto parts store? Also, what plug gap are you running?
Thanks,
Jody J.
Thanks,
Jody J.
no plug gap they are side cut for racing i got them at a dirt/asphalt speed store for $23 summit wants $4 a plug so try to find them local before ordering
Thanks for the info. I tried Jegs and they wanted $5 a plug
I'll try the local stores first before I hit up Summit.
Do you know if these will work with a 150 - 250 shot of nitrous?
Thanks,
Jody J.
I'll try the local stores first before I hit up Summit.Do you know if these will work with a 150 - 250 shot of nitrous?
Thanks,
Jody J.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
jasonduaine
Mar 7, 2015 09:44 AM
