Hi or Lo press fuel pump?
Old Sep 11, 2004 | 09:30 PM
tanmanski's Avatar
New Era has a killer price on Walbro pumps. I'm thinking about getting one to replace my OEM unit. I'm pretty much stock, & will be bolt ons at the most in the near future. NEPP web site shows a lo press & a hi press pump for my year car. How do I know which one I need? Did a search couldnt find anything relevant to this ?
TIA,
Ian
Old Sep 11, 2004 | 10:13 PM
Josh-'04 GTO's Avatar
Re: Hi or Lo press fuel pump?
Low pressure is fine for naturally aspirated setups. Go with high pressure if a blower or nitrous is in your future.
Old Sep 14, 2004 | 08:08 PM
tanmanski's Avatar
thanks Josh. Any downside to using the Hi press pump on a N/A engine? I assume the fuel pressure regulator will handle it for me? Just in case I do go wild later....
Old Sep 15, 2004 | 07:34 PM
Not really. Technically the higher pressure pump probably heats up the fuel a little more. I wouldn't think twice. Get the high pressure pump for when you get the urge for more power. And you will. We ALL do!
Old Sep 15, 2004 | 07:38 PM
tanmanski's Avatar
roger that! thanks Josh. I got the desire to go fast, now if only I had the $$!
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
