Hey need little help
Old Jan 2, 2008 | 10:52 PM
Bigrick2324's Avatar
Im doing egr delete and stuff so do i take off all my egr stuff and what about the hose i have left over and stuff plz right back thanxs
Old Jan 2, 2008 | 11:00 PM
You cap the vacuum nipple on the intake manifold with a vacuum cap. You remove the vacuum lines, EGR vacuum solenoid, EGR valve and the riser pipe from #8 primary to the back of the intake manifold. Cover the hole on the #8 primary and the EGR hole on the back of the intake manifold with cover plates. Cover plate for the riser tube connection on the back of the intake is optional, if you have removed and blanked the EGR valve hole. Have the codes for the missing EGR solenoid and for the lack of EGR flow prorgammed out of the PCM. There will be no hose "left over".
Courtesy of Shoebox:
http://shbox.com/1/egr1.jpg
Might want to add the year of your engine... the 93's are slightly different than the 94-97 EGR plumbing.
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
alex5366
Jun 14, 2015 10:31 PM
jocamino
Jun 4, 2015 09:33 AM
G-BODYT56
Parts Wanted
May 31, 2015 12:09 PM
mike24
Aug 7, 2002 10:06 PM
