Hesitation up top. opti??
Old Jul 8, 2003 | 01:38 AM
  #16
GreenZ28in503's Avatar
Originally posted by InjectedSS
I was just going to ask "does it feel like your hitting the rev limiter" and you said "YES" it does! its DEFINATELY the opti then! ive seen it all and thats DEFINATELY an opti issue.. my guess is that you broke one of the two tabs that hold the metal contact on the rotor and soon enough the other tab will break and the car will not run at all! its the opti! just go to autozone and pick up #30-1833 if you have the vented opti! this is their new set and its a FULL cap, rotor, and distributor set for only $130.00 cant beat that!
http://web.camaross.com/forums/showt...hreadid=142546
So far you are the only one to see this. Everyone else who has researched has come up will information contrary to yours. Don't go getting everyone's hopes up.
(BTW Part #30-1833 here at my local AutoZone was just the aluminum body as well. I was near there today and checked.)
Old Jul 9, 2003 | 09:21 PM
  #17
96SS232's Avatar
it could be the opti. havent ruled it out, but im gonna try other things first b/c it would be one hell of a coincidence that ive had 3 bad optis. i got the last one under warranty from the dealer, if this one is bad, im gonna shove it up their asses. then convert to a coil pack setup. ill keep you posted, im starting on friday.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
marlar98
Oct 21, 2015 02:02 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
tdigger9899
Sep 7, 2015 10:56 AM
