Hesitation in the rain
Old Nov 29, 2006 | 08:23 PM
quick98's Avatar
Here's the deal...
Last time it rained (I don't remember how long ago it was) and I drove the car it started missing and running like poop, just hesitating and studdering and what not. Well I got back home and check the plugs and found that one was loose (somehow). I tightened and everything has been fine until tonight.
I drove to Walmart and before I even made it there it started running just the same as last time. Hesitating, stumbling, missing and just running like crap.
It does it for a few seconds, goes away and runs fine for a few seconds, and then comes back again.
I'm starting to think that it may be something with my opti but I'm not sure. They car has 86K miles on it and basically stock with headers only. Does this sound like something the opti would cause when it gets wet or could it be something else??
Old Nov 29, 2006 | 10:17 PM
GMRL's Avatar
What kind of plug wires are you using? My elitespark plug wires do that when it rains. They get wet and its starts to missfire, just what you explained.
Old Nov 30, 2006 | 03:36 AM
SS RRR's Avatar
check to make sure your water pump is not leaking onto the optispark.
Old Nov 30, 2006 | 04:01 AM
2000GTP's Avatar
Check all of your plug wires to make sure they are firmly seated on both the opti terminals and the plugs. You could also try to spray the wires with a spray bottle while the car is running and see if you can duplicate the problem.
Old Nov 30, 2006 | 09:15 AM
quick98's Avatar
I have NGK TR55 plugs and Taylor wires. They've been on there for about 1500 miles. I'm going to wait until it warms up a bit before I make sure they are all snug. The rain turned to snow last night.
SS RRR - I don't think it's the water pump only because it runs like crap when it rains. It runs excellent when it's dry out.
Old Nov 30, 2006 | 09:46 AM
1racerdude's Avatar
Your opti or plug wires are getting damp and cross firing or jumping to ground. Separate the wires better or get a new set and clean the porcelain on the outside of the plugs.
Old Nov 30, 2006 | 03:32 PM
Steve0's Avatar
Elite's wires were notorious for that. My set held up well for a few months, then started doing the same thing. Worse wires I have ever had.
Old Nov 30, 2006 | 03:34 PM
2000GTP's Avatar
Yep, same here. Luckily I have only been caught in two rainstorms so it isn't a big deal. Very aggravating though when the wires were only a couple months old and ran almost 90 bucks.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Daluchman1974
Sep 11, 2015 06:12 AM
