Hesitation in the rain
Here's the deal...
Last time it rained (I don't remember how long ago it was) and I drove the car it started missing and running like poop, just hesitating and studdering and what not. Well I got back home and check the plugs and found that one was loose (somehow). I tightened and everything has been fine until tonight.
I drove to Walmart and before I even made it there it started running just the same as last time. Hesitating, stumbling, missing and just running like crap.
It does it for a few seconds, goes away and runs fine for a few seconds, and then comes back again.
I'm starting to think that it may be something with my opti but I'm not sure. They car has 86K miles on it and basically stock with headers only. Does this sound like something the opti would cause when it gets wet or could it be something else??
Check all of your plug wires to make sure they are firmly seated on both the opti terminals and the plugs. You could also try to spray the wires with a spray bottle while the car is running and see if you can duplicate the problem.
I have NGK TR55 plugs and Taylor wires. They've been on there for about 1500 miles. I'm going to wait until it warms up a bit before I make sure they are all snug. The rain turned to snow last night.
SS RRR - I don't think it's the water pump only because it runs like crap when it rains. It runs excellent when it's dry out.
Yep, same here. Luckily I have only been caught in two rainstorms so it isn't a big deal. Very aggravating though when the wires were only a couple months old and ran almost 90 bucks.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
