hesitation / fuel pressure issue
Old Aug 14, 2005 | 07:41 PM
southern78's Avatar
The fuel pressure is 38 PSI but without vaccum assit its 42ish. any suggestions?
New fuel pump and filter.
Old Aug 14, 2005 | 08:24 PM
93transam1234's Avatar
Re: hesitation / fuel pressure issue
isnt that what is hould be, check in he dark and see if you can see any of your plug wires arching
Old Aug 14, 2005 | 10:17 PM
southern78's Avatar
NO arcing. Maybe a misadjusted rocker?
Old Aug 14, 2005 | 10:21 PM
Looks close to normal.... you might want to mention what year, major mods etc. The "signature" field is useful for that purpose.
Anything between 41-47psi without vacuum compensation is acceptable. When you reconnect the vacuum compensation line, pressure will drop in proportion to intake manifold vacuum.... an 8psi drop might be seen on a stock cam, maybe as little as 1/2 of that with a more aggessive cam. The real question is does the system hold 42psi all the way up to max rpm/max load?
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
