Here's a good one to figure out!!!
I have a 95 T/A M6. I can rev the motor up fine when not in gear, But I cannot rev up fast when taking off, It will bog down. I can slowly take it up to any speed, When I shift, I shift at 3000 rpm, cause it will start to like cut out. but I let off the gas a little, and it steadly picks up speed.
Anyone have this happen before, I am not throwing any codes, and my check engine light only comes on if I floor it, of course the car bogg's down at that point, and when I let off, the light goes away.
Re: Here's a good one to figure out!!!
I have only had the car a couple weeks, and have done nothing to it.
I dont even think it the owner took car of it, the oil was black, the air filter
is pretty bad
. I was thinking a good tune up would and should help. 133000 miles on it.
Bosch platniums ok for plug's?
is pretty bad
. I was thinking a good tune up would and should help. 133000 miles on it.Bosch platniums ok for plug's?
Sounds to me like you have a bad plug and or bad wires. Unfortunately replacing them is murderous hell on your hands and back but it will most likely(99% certainty) take care of the problem. And bosch plats work for me.
Originally Posted by Silver
Clogged fuel filter?
till I can get a new one.
How do you know when you need new O2 sensors?
Fbodfather
25
Jun 21, 2002 04:12 PM
