Here's another of these HELP posts.
Just finished putting the engine together and got it started ( on the first crank
he he
All was good until we drained the oil after around 15 min....
There was a lot of Water in the oil ... I do not believe to be condensation.
Please confirm my susspect of a headgasket issue
The heads and block were just machined and we are using Cometic Multi layer steel head gaskets for we were told they would not leak but i think they are...
ANYOTHER POSSIBILITIES I'M NOT THINKING OF?
ALSO the idle was very high ( 2000 ) RPM with the new PCMfor less tune- i do not blame the tune ( yet) he he
j/k alvin... I believe it to be a IAC issue- if anyone has any input please let me know..
PLEASE HELP
I plan on digging in......
and taking the heads off tomorrow if no replies...
he he All was good until we drained the oil after around 15 min....
j/k alvin... I believe it to be a IAC issue- if anyone has any input please let me know..PLEASE HELP
Re: Here's another of these HELP posts.
Well i have heard of cometic's having issues sealing if the block surface is not prepped accordingly.. did you torque everything down correctly? etc..
Originally Posted by MyShibbyZ28
Manifold.
Everything on the manifold is all set - Could it be an IAC sensor problem? Something about throwing counts- illl search around the forum for that.
Anyother advice?
Dec 2, 2003 06:49 PM
one wicked element
Sep 20, 2002 11:02 PM
