93 lt1 into 94 3.4
Old Jun 8, 2006 | 10:56 PM
jt7928's Avatar
93 lt1 into 94 3.4 wiring issues
I have a 93 six speed LT1 TA (wrecked) that I bought to transplant the driveline into my 94 3.4l auto Camaro. What do I have to do to get it to run and work with the 94 wiring inside the car? I don't care about nuetral safety switches or clutch switches so if there is a need or a way to bypass them that would be fine. Also , is there any other changes as far as fuel pumps or speedos are concerned that will have to be made? I can get the car to roll over but not run. I have fuel at the rails and 12 volts to the coil. If I put gas down the intake it will run off that but then dies. I have power to the injectors but no pulse signal to fire them, any ideas would be a big help
Old Jun 9, 2006 | 07:27 PM
jt7928's Avatar
Re: 93 lt1 into 94 3.4
I am lost on this one so any help would really be appreciated. Is it possible that the six cylinder fuel pump isn't enough for the injectors, or is there a wire on the ecm that needs to be hot that maybe isn't do to the 94 wiring?
Old Jun 11, 2006 | 04:06 PM
jt7928's Avatar
Come on guys someone has got to have some idea why I don't have any injector pulse from this car. I changed the pump still no pulse. I know it is fuel because it will run on fuel poured down the intake so it has spark. And check for power at the injector, it is there just no signalto fire them?
Old Jun 11, 2006 | 09:36 PM
easyc4's Avatar
goto www.tacreationsusa.com
it basically states that you ahve to change the entire dash harness
Old Jun 12, 2006 | 01:22 AM
kingslam's Avatar
you need a 94 or newer wire harness, engine etc... sell the 93 set up?
Old Jun 12, 2006 | 02:16 AM
tritonium's Avatar
I did this exact swap 2 years ago
My AIM screen name is dastrikatank
IM me and id be glad to help you.
SpeedJunkee
Jan 27, 2015 10:02 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
TheV6Bird
Aug 27, 2002 10:38 PM
Eric H
Aug 10, 2002 06:39 AM
TheV6Bird
10
Aug 2, 2002 08:00 PM
