Helpppp!!!
Old Dec 21, 2003 | 11:33 PM
96ta(nick)'s Avatar
Helpppp!!!
The End of my dam Low oil sensor broke off in my oil pan!!! i have the motor jacked up as far as it will go and can not get the pan out! How do i get the pan out of the car? I have an M6. Do i need to drop the cradle? and how would i go about doing whatever i need to do?:
Old Dec 21, 2003 | 11:35 PM
jonaddis84's Avatar
You will probly either need to pull the tranny backwards slightly, or lower the kmember, I tried as well and i had to pull the tranny back slightly if I remember correctly, good luck, that sucks man.
Old Dec 21, 2003 | 11:37 PM
96ta(nick)'s Avatar
hmm pull the tranny back slightly... what do i need to do to do that?
Old Dec 21, 2003 | 11:41 PM
Trans-Am's Avatar
Don't quote me but if you drop the cradle down a bit, zip the bolts out and lower it down a bit with a jack. It will be a lot easier than pullin the trans. Just a thought how the hell did you break the sensor anyway?? Good luck man
Old Dec 22, 2003 | 12:01 AM
96ta(nick)'s Avatar
i started to pull it out and the end slid off and fell in the pan! I was like WTF!?
How would i go about dropping the cradle?
Old Dec 22, 2003 | 12:03 AM
notstock4long's Avatar
Would it really hurt anything if you just left it in there? I mean, if it is in the deep part, it shouldn't get sucked into the engine or anything. I think....
Old Dec 22, 2003 | 12:07 AM
96ta(nick)'s Avatar
i was thinking the same thing but it seems like
too big of a risk to me.
Old Dec 22, 2003 | 01:13 AM
96ta(nick)'s Avatar
ttt
Old Dec 23, 2003 | 02:16 AM
TW95Z's Avatar
If I remember correctly from what I've read, support car using jack stands on the frame (not the front suspension or tires on ramp), disconnect the steering shaft from the rack and pinion. Loosen the 6 subframe bolts about 2 to 2 1/2 inches. They are fairly long and will let the cross member drop enough to remove the pan.
Old Dec 23, 2003 | 02:24 AM
96ta(nick)'s Avatar
do i need to support the front suspension or will the bolts support it enough?
Old Dec 23, 2003 | 11:03 AM
I would think that the bolts would support it enough.
miss97z
Parts Wanted
Jul 31, 2011 02:07 AM
ONELOUDKAR
Jun 23, 2003 01:53 PM
